<<< New Site Update >>>
Studs to mount carb to short on 200 6 stock spacer w phenolic. Where to get longer studs?
reweb67
Post #1 by reweb67 » Tue Feb 13, 2018 10:31 pm
Car is a 1967 Mustang.
I have the stock spacer that goes on a 200 six. The one that supports the throttle linkage and has the area where the heater hose will run through it. I'm adding a phenolic spacer and need the studs to be 1/2 inch longer. I was able to remove the current studs no problem. Anyone know where to get longer ones? Thanks for any help!
gavinpais
Re: Studs to mount carb to short on 200 6 stock spacer w phenolic. Where to get longer studs?
Post #2 by gavinpais » Tue Feb 13, 2018 10:56 pm
I believe Vintage inline sell different lengths.
https://www.vintageinlines.com/product- ... -stud-kits
StarDiero75
Post #3 by StarDiero75 » Tue Feb 13, 2018 11:01 pm
Howdy
I changed my studs, i got them at the local hardware store. Its a more specialized place called Tacoma Screw.
Good luck,
Ryan
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
reweb67
Post #4 by reweb67 » Wed Feb 14, 2018 5:47 pm
I was surprised to find them at my local hardware store so all set. Thanks for the replies
StarDiero75
Post #5 by StarDiero75 » Wed Feb 14, 2018 9:01 pm
reweb67 wrote:I was surprised to find them at my local hardware store so all set. Thanks for the replies
No problemo man.
Good luck
Ryan
Econoline
Post #6 by Econoline » Thu Feb 15, 2018 12:19 am
Any hardware store should have them.
It ain't gonna fix itself
Users browsing this forum: No registered users and 21 guests
