2018 Contributors:
Autolite 1100 check balls?
falcon_master
Post #1 by falcon_master » Sun Jul 01, 2018 4:18 pm
Hi everyone. So I was writing to say I did purchase my carb rebuild kit it should get here soon. But I was disassembling the old guy and notice I only had one check ball in it. It was in the accelerator pump hole. Am I supposed to have more than one in a carb and where could I get them if I needed to. Thanks. Another question is is it really necessary to have some gauges for oil pressure and water temp for this engine. I heard it's much better to use real gauges rather than a dummy light or a not very accurate gauge but it's gonna take some rigging to make work so I wanted to know if it was really worth it thanks
Junior year high school AFJROTC cadet and car enthusiast. Likes all things ford and engines of any company. 64 falcon 2dr sedan,144CI and 3spd column shift. estimated 124,000 miles. Resurrected after sitting outside for 18 years, In process fixing for use as daily driver YouTube channel for repairs coming soon. “Old cars may break but are never broken”-RCR
chad
3 or 4 check balls?
Post #2 by chad » Sun Jul 01, 2018 5:20 pm
up to 4 on some I think...not up on that carb.
Go to Mike's "videos" on UTube.
He's great:
http://www.carburetor-parts.com/search. ... rch=search
shows 4 but not where they go. Search around the site 2 C exploded diagrams of where they R.
/OR/
His vid sez some R varable I think. His vids have helped millions.
https://www.youtube.com/watch?v=uiOG__H2BM8
(that might B it, yes, it is but watch the series to observe the whole rebuild process. Buy frm him to support the great wrk he duz just like Matt w/VI). We wanna support the best!
jimlj66
Re: Autolite 1100 check balls?
Post #3 by jimlj66 » Sun Jul 08, 2018 12:16 am
It seems like the last rebuild kit I purchased came with check balls. I think there are a couple weights that do not come with the kit. Be careful you don't loose them.
292_fan
Post #4 by 292_fan » Tue Jul 10, 2018 7:54 pm
I have a 63 Falcon 170 with that carb. 2 check balls are mandatory. A 3rd check ball is used if you have an auto trans, and a 4th check ball is used if you carb is on a 223 Parcel truck or 262 truck. This from my 63 Falcon Shop Manual. Hope this helps. Not sure how to post pics on this site, bit if you need them, we'll figure something out.
dagenham
Post #5 by dagenham » Sun Jul 15, 2018 8:43 am
Just rebuilt my 1100 two weeks ago. The kit from Autozone came with three check balls. Mine was a 66 mustang though so I don't know if yours will be different. Ditto about the weights. The kit does not have those.
Lights only come on when its to late basically. Guages are definitely better because you can see a problem starting maybe. Hooking them up is pretty straight forward and not to difficult. Mechanical guages are better imho and easier to hook up than electric gauges. Less wiring with mechanical gauges too.
Users browsing this forum: No registered users and 28 guests
