Starter Arcing
StarDiero75
Starter Arcing
Post #1 by StarDiero75 » Tue Jul 17, 2018 3:25 am
Howdy guys,
I just finished my engine swap and my starter keeps sparking at where the line to it goes. The starter is new (rebuilt) so i dont see whats wrong with it. Didnt have the issue before. The bell, block plate, and starter are the same, so nothing changed
Also, it runs guys!!
Before:
https://photos.app.goo.gl/HVj3TJcV2LNVgQfd6
After:
https://photos.app.goo.gl/a5N6o2ZRsjnSmSGC9
frozenrabbit
Re: Starter Arcing
Post #2 by frozenrabbit » Tue Jul 17, 2018 12:10 pm
You could have a crushed or broken insulator at the terminal.
'New' and 'rebuilt' doesn't mean much these days
ags290
Re: Starter Arcing
Post #3 by ags290 » Tue Jul 17, 2018 12:29 pm
Are you sure that all of your grounds are in place?
Kevin
Early 1965 Mustang with a 170
StarDiero75
Re: Starter Arcing
Post #4 by StarDiero75 » Tue Jul 17, 2018 1:10 pm
ags290 wrote:Are you sure that all of your grounds are in place?
It is snugged up tight to the block. The nagative for the battery is snug on both the block and battery. The alternator ground is snug. The coil ground is snug.
Could it just be a crap Starter?
Re: Starter Arcing
Post #5 by bubba22349 » Tue Jul 17, 2018 1:24 pm
If the starter has been removed repeatedly lately then it could be as simple as the starter stud nut backing off enough to be lose. Ie the stud on the starter for power cable from the solenoid. Good luck :thumbup: :nod:
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
chad
Re: Starter Arcing
Post #6 by chad » Tue Jul 17, 2018 1:35 pm
motor grnded to frame'n firewall
those 2 'straps' crushed under the motor on install/left off
StarDiero75
Re: Starter Arcing
Post #7 by StarDiero75 » Tue Jul 17, 2018 2:09 pm
bubba22349 wrote:If the starter has been removed repeatedly lately then it could be as simple as the starter stud nut backing off enough to be lose. Good luck :thumbup: :nod:
Ive tightened both of those nuts on the starter and the bolts that hold it to the bell
StarDiero75
Re: Starter Arcing
Post #8 by StarDiero75 » Tue Jul 17, 2018 2:10 pm
chad wrote:motor grnded to frame'n firewall
What straps? Ive never had straps on the starter and never had this problem before. Could tge bell just be dirty or oily where jt contacts?
chad
Re: Starter Arcing
Post #9 by chad » Tue Jul 17, 2018 2:56 pm
"...never had straps on the starter..."
again, Y the use of shop manual wuz suggested. I'm not good at all on ele systems 4 auto (can do a house OK) & am only thinkin bout how these old vehicles have 2 grnds...1 to frame, 1 to fire wall. Rubber (if done correctly) in engine towers/mounts isolates.
What I offer is not bible, only suggestions and thoughts. I C in the manuals to follow this procedure tho.
The technical is beyond me so I just mimic the correct.
Re: Starter Arcing
Post #10 by bubba22349 » Tue Jul 17, 2018 4:21 pm
Ok then it’s the insulator as “ frozenrabbit” said so get another starter if it’s got a warrantee still outerwise you will need to disassemble enough to get in and fix it. Good luck :thumbup: :nod:
Econoline
Re: Starter Arcing
Post #11 by Econoline » Wed Jul 18, 2018 12:00 am
When you say it's arching, where do you see it?
It ain't gonna fix itself
StarDiero75
Re: Starter Arcing
Post #12 by StarDiero75 » Wed Jul 18, 2018 12:35 am
Econoline wrote:When you say it's arching, where do you see it?
Its right on the starter where the power line for it connects to it. Its fine for a split second, then a little bit of smoke, then it starts sparking like heck on it. Is that not arcing? I may be using the wrong term
Econoline
Re: Starter Arcing
Post #13 by Econoline » Wed Jul 18, 2018 1:33 am
Maybe the terminal or wire lug is somehow shorting to the starter frame at/near the terminal. I'd pull the wire from the starter and investigate. You'll be able to see where and maybe how it's arcing to ground from the black traces and melted steel and copper.
drag-200stang
Re: Starter Arcing
Post #14 by drag-200stang » Wed Jul 18, 2018 9:01 am
Sounds to me that the connection is dirty or not tight, maybe wrong nut...Take it apart and clean with scotch brite, tighten nut close to starter first then wire and tighten last nut.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
mustang6
Re: Starter Arcing
Post #15 by mustang6 » Wed Jul 18, 2018 1:41 pm
I agree likely a broken/compromised insulator. The stud itself has one nut that holds it tight to the insulator/case and if that gets loose then tightening the second nut that secures the battery cable can cause the stud to spin and possibly ground out inside the case. Overtightening can just crack/smash the insulator as well.
Scott
Users browsing this forum: No registered users and 38 guests
