‘74 250 - timing chain - how much slack is acceptable?
62Ranchero200
Post #1 by 62Ranchero200 » Sun Mar 22, 2020 10:08 am
My 250 has about 10,000 miles on it. Pulled the old cam out last night, and timing chain can be deflected about 1/2”. There are no wear marks and everything otherwise looks good. Gearset with chain were new when engine was built six years ago.
Is this ok?
Bob
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
chad
Post #2 by chad » Sun Mar 22, 2020 11:24 am
"... how much slack is acceptable?..."
my eye & fingers say 'none'. Sorry don't
have a 'deflection measurment' ona dial
indicator. If I could move it a 1/2 inch I'd
start over...look at other 'looseness'.
wsa111
FSP Moderator
Re: ‘74 250 - timing chain - how much slack is acceptable?
Post #3 by wsa111 » Sun Mar 22, 2020 12:15 pm
Since its not a roller chain, replace it. If gears show wear do the same.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
CZLN6
Post #4 by CZLN6 » Sun Mar 22, 2020 4:03 pm
Howdy Bob and All:
Since you have it apart, replacing the chain is cheap insurance. You said the current chain has 1/2" of slack, or deflection, check the new chain for comparison. And let us know. You might also do some testing on how many degrees of cam movement between the two points of slack. Chain slack, due to wear, causes the cam to act like it is being retarded. That is not near as bad as if it is being advanced- for performance. Chain slack, as the engine accelerates and decelerates causes wear to the cam gears.
Also check your rocker arm shaft to make sure that oil is getting to the front rocker arm and draining freely down.
Keep it coming.
Users browsing this forum: No registered users and 29 guests
