Hello Everyone!
I am starting this topic due to my recent decision to dive into the motor.
Here is a quick recap: The falcon has been sitting for over 20 years, the motor was starting then stalling. I put in a new fuel system front to back. Rebuilt carburetor, new ignition switch, starter solenoid, starter, coil, wires, dizzy cap, rotor, points, and condenser. I may be missing something but ask if needed.
Starting compression when I got the car, just to check if it would run was between 65-90 on all 6 cyl. Compression now is 1:65 2:135 3:140 4:135 5:135 6:140
Thats when I decided to dive in to find the problem, seems like there was a broken ring and it scraped with cyl wall. If you want to see the whole process getting to this point see the thread: Smoke from Carb, where my project continues to snowball.
Where I am at now: Head is off and out of the car (working on disassembly of all the valves to clean and hand lap them. Block is still in the car, I have no room or hoist to remove it. I did however manage to ridge ream and hone all 6 cyl. So far everything is going smooth! I plan on doing a rering kit, all new gaskets and hand lapping the valves and see what happens.
Most important right now! Bubba recommended a kit from falconglobal on ebay: What size bearings and rings do I need they say I have to specify the size? I'm looking at this from work so I don't have my handbook in front of me. I'm not sure if I should be ordering oversize rings or if the standard will still be good after honing?
https://www.ebay.com/itm/Ford-rerin...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
And if you want to look at the pictures I have tons but I am trying to organize before It gets out of hand:
https://drive.google.com/open?id=1TRi85PytyK_y8zb6zSPmKXMaO-EmcqLh
Thanks for everyones help so far on the other topic: Hoping to continue to learn and get this ol' girl back on the road before summer!
But. It has reduced in size my fingernail will barely grab it now. I’m going to hone again before I put everything back together and work out the ridge a little more. I started cleaning up the other pistons and noticed some pretty bad pitting, I don’t have photos yet and honestly plan on using it anyway. I should have assumed that this old neglected falcon, i would find some strange things.
