Howdy Tatao,
     Remove the air cleaner, (the element is clean, right?) the choke plate is the topmost flapper thing inside the carb. When the engine is cold, the choke should be just closed, but should open with light finger pressure. If it has an electric choke, turning on the ignition key should energize the heating element which will cause the choke to come open. If it is non- electric, then you will need to warm up the engine to see if the choke opens. If the choke is adjusted too tight, you can loosen up the choke spring element and rotate it to where it just closes. This is usually a small round gizmo on the end of the choke shaft. The choke MUST be fully open when the engine is at normal operating temperature. To check the float level requires removing the top of the carb,probably best to remove the entire carb from the engine first. Turn the top part of the carb upside down, and see where the float is setting. This needs to be set to the book specification for your particular carb. Also a leaky float can sink in the float bowl and cause the fuel level to be higher than it should, resulting in high fuel consumption. You said this is a new carb, did the fuel mileage get better, worse, or stay the same compared to the old carb? I probably wouldn't pull the carb just yet, make sure that the ignition timing is correct, and that the vacuum advance is hooked up and working properly. What are the chances that a 1979 Chevy in El Salvador has all of the proper vacuum lines, etc. attached? Try to find a service manual for this car and get everything set up as close to factory specs as possible. Don't worry about doing special mods yet, you need to get the performance up to stock levels first. That will be tough to do with a worn engine that burns oil. If it never gets driven at high speeds, try a hotter spark plug to keep the deposits burned off. I would put in the hottest ones I could find, and then monitor them closely. An oil burner can also plug up an exhaust system pretty badly. Does the car have good power or does it seem pretty sluggish? If you let this car idle a lot it will really plug things up, and remember, you get zero mpg at idle. Having driven old junkers most of my life, I know just what it's like, and sometimes there is no cure but an overhaul. This should be enough to keep you busy for a while, keep us posted on your progress
Lazy JW
