I'm trying to get my 75 Jeep started and because I don't have a key and I don't fully trust the wiring, I'm trying to take this in steps. Bump the motor with the starter, check for spark, nail down the fuel.
Anyways, my Jeep has a ford style starter with the solenoid (relay) mounted elsewhere besides the starter. In the past, I've jumped the two large terminals (with the key in the run position) on a suspected bad solenoid to get a car started. This style of solenoid is kind of hard to do that with.
I also can't get anything out of applying 12vdc to the output terminal that goes to the starter. I got some sparks and my jumper got hot.
I'm wondering what could be wrong. I've never had a solenoid not turn the starter when you got 12 volts to the output terminal. Bad Starter? Bad Ground on the solenoid? It's pretty crusty under there. Do I try to apply 12 volts to the starter directly? Do I pull the starter and test it off the vehicle?
The other day I was trying to start it and got the starter to turn for a split second.
I'm also trying to avoid investing any money that I can't recoup part of if I decide to call this a wash.
or you could take to your local auto parts store were they likely test it for free. good luck
