I just reinstalled my full refurbished single-barrel Holley carb in my '59 Edsel Ranger after the car had been sitting for about 2 months without being started. The good news is that it started right up. The bad news is that now there is a major knock coming from the engine that was not here when the car was last run. Before I start the process and major expense of dealing with a mechanic does anyone have any ideas of what it could be?
The engine is a 223cid I6. The whole story is that a about four months ago I tuned up the car, added new oil, new plugs, changed out wires, etc. even changed out the fuel tank and it was running perfect (for a couple of months). The only problem was that it was hard starting and the carb leaked gas.
After several attempts to stop the leaking, I decided to send the carb out to be completely refurbished/restored. So the car sat idle for about two months while I finally sent the carb in and it was returned.
Once I installed it (I also installed a new inline fuel filter between the pump and the carb - the old one that had been on the car had its glass bowl cracked) I had to pour gas into the carb several times to get everything primed and back running. It started great, but within a few seconds it started to have a low metallic knock, which increased in volume and pitch when the engine was revved/gunned. There was also a hissing sound like air being sucked or blown out somewhere. At that point I turned off the engine, and left in despair! (Just kidding - sort of)
I have sense looked through the info I have discovered that it could be anything, from bad gas (which I can probably rule out since I am using the same gas in my regular car) to major mechanical issues. I have also read that there could be some vacuum issues with spark advance on the I6 engine. Once I regain the courage and patience I will try to resolve the problem.
Any words of wisdom would be greatly appreciated.
The sad part is that I purposely choose an Edsel with an I6 engine for my future daily driver, because I had always heard how foolproof and easy to work on this engine was. I guess that may be true UNLESS it is installed in an EDSEL. (Gotta love that car!….'Cause love is BLIND)[/i]
