223 engine performance upgrades
Tanman-67
New Member
Post #1 by Tanman-67 » Sun Jun 10, 2018 3:24 pm
Hey guys, i have a 1962 ford f100 unibody with a 223 I-6. Im going to pull the motor out and bore it .60 over shave the head .60 over. Port and polish the head. Clifford 268 cam. Holley 4 barrel carb with clifford intake manifold and header. I may do a dui distributer. I am wondering how big of a lope the 268 cam will give me? I want this little 223 to be turning heads. I am also wonering if i need to do arp head studs for the higher compression or if arp even makes head studs for it. Thanks
Re: 223 engine performance upgrades
Post #2 by bubba22349 » Sun Jun 17, 2018 12:35 pm
The ARP Rod, Main, and Head bolts are available for the 223, so probally the Head studs are available too. You can see the ARP Head bolts in the below link of the 223 Performace build. Best bet is to contact ARP direct on what the part number is for studs that you would want. Good luck on your 223 build. It would also be a good idea to consider installing a set of the ARP Rod bolts too for your build up, and before you rebuild the rods. :thumbup: :nod:
223 Performance Build
viewtopic.php?f=18&t=76750
Picture of the 223 ARP head bolts
download/file.php?id=1815&mode=view
Users browsing this forum: No registered users and 13 guests
