check check... is this thing on?
just ordered a brand new DS dizzy from rockauto, it was 55 bucks with a $5 core charge... its probably going to cost $5 to ship my dizzy back so screw it, i might want to rebuild it anyhow and just have it on the shelf in case. I just bought brand new points, cap, rotor anyway.
i got the '2 vacuum' unit, which looks like it just has a tap for both sides of the vacuum can. Unfortunately the can itself is crimped on, so no adjusting of the springs there. Maybe i can use some kind of bleeder orifice if i have to adjust the boost-dependent retard.
So i'm thinking, hook up the main (advance) port to the manifold vacuum and hook up the secondary (retard) port to the carb hat/ inlet piping so it sees only boost. Do i need a check valve in the main line to manifold so it doesn't see boost?
I'll probably hook it up with compressed air and plot out the advance/retard curves based on vacuum/pressure.
EDIT: ok, so i guess i was a bit confused on this, the vacuum advance pulls the timing more advanced at high vacuum? hence being called 'vac advance' duh... so wouldn't pressure on the opposite side of the membrane, where the porting is on the '2 port' dizzy cause the same effect, pushing on the membrane and increasing timing with boost?
If the vac advance works the way i think it does, you'd want to put a heavier spring in it and set it so '0 vac' is somewhere advanced of stock, say 10 degrees or so, then you would have ten degrees of travel in the pressure direction (retard) and 10 degrees in the vacuum direction (advance) and clock your distributor so at idle you are 25 degrees or so. That way high rpm, low pressure means you are advanced mech. plus advanced vac. High rpm high pressure means you are advanced mech plus retarded vac. Low rpm means retarded mech, and advanced/retarded the same for vac/pressure.
Now i'm wondering what the mechanical limits and parameters of this thing are and whether it wouldn't be a lot easier to go TFI using a microcontroller, manifold pressure sensor, and temp sensor... I'm looking at some projects people have done with Arduinos and it is pretty slick!
