I've got a idea in the back of my mind, and decided to test the waters.
I'm looking for a 4.1L Crossflow engine located in the USA. The thing is, I'm needing one of the later blocks that uses the larger rear main seal. This would dictate a block with a casting code of 86DA+, but the 84DA block can be machined to accept the later seal (recently found out some the of 84DA blocks even came with the later seal). Short block would work since I already have several heads. Heck, even if you just have the block, oil pan, and cam cover that would be enough to start with.
Email or PM me.
Oh, I also need a standard bellhousing.
Thank you,
Email or PM me.
Thank you,
