76Da block - Clutch Fork
hucklburry
Post #1 by hucklburry » Wed Oct 17, 2018 8:30 pm
I picked up a 76DA blocked engine, and I have the bellhousing, but I didn't snag the clutch fork and didn't think much of it.
Well I should have. I am using a 66 Bronco clutch fork and it just has to be too long, the throwout bearing is off to the right of center.
The Bronco has a 146 tooth or so flywheel, it was behind a US 170 six. That is the clutch fork I was trying to use.
Is there a US application with a clutch fork that would work? Maybe a 65 mustang or something?
Rocklord, can you measure a clutch fork, if you can find it, I think you'd have one laying around?? Maybe from the "crease" where it rides on the bellhousing tab to the end where the throwout bearing mounts?
--Jim
rocklord
Re: 76Da block - Clutch Fork
Post #2 by rocklord » Sun Oct 21, 2018 10:33 pm
Jim,
The clutch fork I have is 9-1/2" long tip to tip. The measurement from the pivot (crease) to the end of the fork is 3-5/8".
I'll send you some pix that I took when I get them downloaded.
Hope this helps,
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
rocklord
Post #3 by rocklord » Mon Oct 22, 2018 10:12 pm
Here's some pictures.
Dan
Currently Own
hucklburry
Post #4 by hucklburry » Tue Oct 23, 2018 9:54 am
Thank you! It'll be back together soon.
Users browsing this forum: No registered users and 7 guests
