Lifting assembled 250 engine/long block with aluminum head
62Ranchero200
Post #1 by 62Ranchero200 » Tue Dec 03, 2013 9:02 am
Greetings Ford Six Fans,
Don't know about the stock configurations for the 144-170-200, but my 250 originally came with "lifting lugs" (flat pieces of maybe 1/8" steel, with round holes that can be used to fasten a hook for lifting the engine). One was mounted at the very front of the driver's side, using two bolts into a boss cast on the side of the block, and I can still use that one. The second one was mounted on the passenger side towards the rear, to the original log head, which I am no longer using.
For those of you who have preferred to assemble your engine as much as possible before installing it into the chassis, what did you use for an attachment point on the passenger side?
Thanks
Bob
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
CoupeBoy
Re: Lifting assembled 250 engine/long block with aluminum he
Post #2 by CoupeBoy » Tue Dec 03, 2013 11:52 am
There have been a few threads on this topic..
removeing engine
Six cylinder lifting points, Where?
-ron
1970 170/C4
1967 200/C4
1975 250/flexplate
1975 300/flywheel
