so im curious about the speedo working once you disconnect the factory computer.... or does the cluster connect directly to the sensor in the axle and doesnt use the computer?
My 95' speedo works without the stock computer, I assumed it was a mechanical drive off the trans but I don't honestly know. My megasquirt has an adapter board that plugs into the stock harness but there are no provisions for the speedo on it.
