dawnovsky
Hi ,
while on my way to do some paint job on the valve cover, for some reason i have to move the car with the valve cover of. I plug the PCV valve to make sure the engine won t die from to much vacuum leak just to find out that the engine run better with the PCV valve plugged .
Better idle, better Neutral to Drive and RPM drop when engaging Drive.
i have never been able to achieve a proper tuning of my 200 with 250-2v head since installed about a year ago.
It was horrible to drive cold (i m leaving in a tropical area so cold does not mean really cold) and RPM commonly drop 4 to 500 when put in drive.
I have seen quiet a few 6cyl engine without PCV and a wonder if can may be live without it as it seems to improve drivability.
I have read open crankcase vent (without PVC, with breather) will reduce airflow on valve cover and engine and increase temp in general specially in timing chain compartment.
what is you opinion.
regards
regards
