he's suggesting an exchange of the water choke (post 12) with what's in post 15?
I C OP has an ele choke already so just bring that dangeling ele.clip to where bubs suggests. (I found an interesting 1. Must B solid state as its wired to a head bolt w/heat sensor. No ele connection)~
The current 'clip' on top the VC is 1/2 of the correct bracket. The eye pointing toward the carb was under the carb ona later model using the same stud as carb. Glad you're not going 'bar linkage'. Wonder what peddle's on there (matches cable probably...
That head w/the nice flat log is one of the best (but not E0x, THE best). Let's ID the block to C if it is late model too?
