Hey everyone. I have been reading about this conversion until my eyes burned out of my head and I have not come across solid info on setup after the fact. I would like to know a few things as I am set to get this conversion under way.
1) what initial timing are you running?
2) does everyone change the mechanical advance springs with the mr gasket 925D kit? If so, did you change one or both springs? Which spring?
3) How much mechanical advance do you have?
4) what rpm do you hit max total advance?
5) what plugs and gap are you running?
6) ported or manifold vacuum?
7) have you installed an adjustable vacuum advance and if so, what did you adjust it to?
FYI, I have a Clifford single Weber 38/38 and header so info particular to that setup would be of even more help. Thanks.
