All right then.
I'm getting ready to order my pistons, and the deck height is now coming into play.
The block I'm using is unmolested, (well,...unmolested up until I got a hold of it ) and never has had any machine work. That said, I guess I now assume, that my deck height is stock @ 9.469".
If it is the same thickness on the big end as a stock 250 rod, at Xctasy's suggestion, I plan to use a 1986 2.5 HSC rod. Length is advertised @ 5.990".
Now, doing some simple math, and dividing the stroke in half, ( 3.91/2 = 1.955) Adding 1.955 to the rod length of 5.990 (5.990 + 1.955 = 7.945). When you factor stock compression height of the piston of 1.511, and add it to the previous,.....you get 9.456.
A piston that will be .013" still down in the hole.
Am I right in my thinking here?
Now, this block is gonna have all six cylinders sleeved, and remain factory standard bore 3.68. Ultimately, I'd imagine they're gonna have to deck it to square it. So If I give them .030 ( plus the stock .013, I'll have normally) to deck the block back to true,..I modify my pin height requirements "up" into the piston commensurately, so my new requested pin height on my custom piston should be......1.481, and it should still be .013 down.
1). So my first question is,...is it safe to assume that a corrected pin height .030 higher in a custom piston will be sufficient to have ample room (.043) to deck the block to zero deck?
You guys getting what I'm sayin',.....you painting what I'm priming here?
Next, I'm using a Crossflow head (HF2 to be exact) Trying to determine what I have from simple internet research yields little about whether or not the head is good or bad based on chamber design considering I'm going to be turbocharging it. It looks "open" to me, but when a gasket is placed on the face of the head, there is clearly two quench areas on both side of the chamber, so maybe I'm wrong in thinking that? I hope to hell that the head I have is gonna work, I'ts waay too far along to be second guessing myself now. Two of the stock valves are bent, which brings me to the quest to correct that. While I thought that there was a bagillion replacement stainless valves out there, the opposite holds true. As long as the intake valve is on a crossflow head, the ONLY valve you can use for an intake replacement is the 1.88 exhaust valve for a BBC. From what I'm reading, I'll have to have that dude undercut to a maximum of 1.84 to not go "too big". Conversely, the exhaust valve can be readily replaced w/ a 1.54 351W sized FMS replacement SS piece.
Trying to research chamber volume yields somewhere in between 53-56CC's. Obviously important to my final piston design, as to be able to figure out how to get a final compression ration of 9.0:1.
I'm planning on using a custom made Cometic head gasket ( will not be a wire-lock design, more of a sandwiched tool steel thing-a-ma-bob from what I'm understanding) Anyway, a .040 compressed thickness will be the targeted design requisite.
So,... Question #2.
All things considered, Is there enough information here to give my piston guy so that he can determine how much of a dish I'm gonna need to yield a final compression ratio of 9.0:1?
3.68 bore, 3.91 stroke, 53CC head, zero deck, .040 compressed gasket?
So,... Question #2.
