jarrod
I have a 64 Ranchero that was given to me by a friend. All he knew is that it had "some work" done. I don't know anything else about who had it before him or what they may have done to it. It was leaking gas around the carb so I went to rebuild the carb the other day and discovered that the needle and seat had been cross-threaded and "sealed." I ordered a new carb and after installing it I realized that the intake bore on the log was 1.425 (or there about, I used a harbor freight digital caliper), too small for the 1.5 butterfly valve on the new carb to open. I put the bottom of the old carb on the new carb and it's running but it really got me thinking about trying to identify pieces of my Franken-engine...
Here's what I know:
The VIN indicates the car originally had a 170
It's definitely got the LOM and a Holley 1940 carb with SCV.
Block: C4DE-6015-A; Blue; 3 freeze plugs; no "T" or "N" block code
Head: C9DE-6090-M; blue with blue valve cover; 1.425 Intake bore
Here's what I think:
I'm guessing that the block is the orginal 170 and the head is a 144 (because of the intake bore). But did Ford make the 144 in 1969 and doesn't the "D" in the code identify it as being for a Falcon?
Any thoughts would be much appreciated!
-jarrod
Here's what I know:
-jarrod
