I have a C3UA casting econoline bellhousing for the early 170/200 engine it has the small bolt pattern for the block and has the narrow top loader/T-10 bolt pattern for the trans, it uses the 3 bolt starter and the small 8.5" clutch and flywheel not the 9" flywheel that requires the large bolt pattern bellhousing and later block. It comes with the fork and block spacer plate, this bell can be used to put a beefier 3 or 4 speed in your Falcon or Mustang or a T-5 with an adapter plate. $ 175.00 + shipping OBO
