Holley Jetting 4412-500 CFM-7448-350 CFM
wsa111
Distributor Recurving.
Staff member
Approved Vendor
Supporter 2018
I have done many months of testing trying to find the right combination of main jets, accerator nozzles, pump cams & power valves on these two carbs. My tests are for the best street drivability, miliage & performance.
The next level is the dyno & the drag strip.
With my engine combination these are the results.
The 4412-500 carb was a hassle, I downsized the accerator pump to the 30 cc capacity, used a modified blue cam with a drilled out accerator discharge nozzle to .0295 with a 2 stage power valve with 71 main jet size.
The results were not what I wanted.
At various ambient temperatures I encountered flat spots.
The final choice was go back to the stock 50cc pump, use the stock brown accerator pump cam, 7.5 power valve to the stock .028 accerator discharge nozzle, with a 71 main jet. The fuel miliage went down slightly, but that was expected to cover up the lean holes in the mixture.
Over all driveability is great with no flat spots & fantastic throttle response.
Your application may require a larger jet size if you have an aussie or argie head with more breathing ability.
Next the 7448-350 carb. That was easy, I used a 59 main jet, 8.5 power valve, .031 accerator discharge nozzle with an orange cam in the #2 position.
Next is a dyno test & or drag strip times to see which is top dog.
Just from the seat of the pants the 500 is much more responsive to the throttle, than the 350 carb but that would be expected, because you are exposing much more air flow at a smaller throttle opening.
The main jet size will vary with your perticuliar combination & use, but this will give you a basic idea where to start.
One thing I found out if you have any camshaft in your engine above stock make sure you run full manifold vacuum to the vacuum advance can to give you a much improved idle, part throttle response & fuel miliage. Only use ported vacuum if you have a stock engine. but you can experment.
Last but not least make sure you have at least 6-8# of fuel pressure with the holley 2300 carburetors & have the float setting correct.
Good luck on your application. William
One area I left out is the automatic choke pulloff adjustment for all 2300 series & including the holley 4 barrel series.
This is from an old post of mine, but I found many users of these carburetors are not even aware that holley has this adjustment feature.
Just a bit of technical advice for you owners of engines with the holley 2300 2bbl or any holley 4bbl with the automatic choke option with this adjustment feature.
The adjustment is for the choke pull off. Many of you possibly have no idea what i'm talking about. When you adjust the choke housing for the proper tension, there is another adjustment many owners are not even aware it exists,
The adjustment is after you start a cold engine the choke blade has to be cracked the correct amount. If the setting is too rich blubbering & black smoke will follow after a cold start, then go away after several seconds or minuites after starting-the other extreme is too much choke pulloff or choke blade opening after startup causing a lean stall. Remember i'm assuming your fast idle cam setting is correctly set.
This setting is on the choke casting. If you are too rich back out the small screw adjustment till the choke blade opens the proper amount to prevent the rich blubbering after cold start-up. If you have a lean stall after start-up you can turn the adjustment in clockwise to slightly close the choke blade for proper richness.
IF YOU MAKE THIS ADJUSTMENT FIRSTS CLOSE THE CHOKE BLADE MANUALLY THEN TURN THE SCREW IN OTHERWISE DAMAGE TO THE CHOKE PISTON IN THE HOUSING CAN BE PREVENTED.
Take a look at the photos & the adjustment screw will be obivious.
Hope this helps many of you holley owners. William
Hope this helps for fine tuning. William
You used three fuel pumps? I see the stock pump, then one under the car and another in the engine compartment.
I forgot to ask. Did you use a stanard or high flow power valve? Also, is the accel. nozzle a straight type or tube type nozzel?
Marco, There is only the stock mechanical pump with a holley 8# pump in the fuel line.
The accerator pump nozzle is the non nozzle type type.
The power valve is the regular flow type, this engine does not require the high flow type with an engine which only puts out 175 HP at its best.
With the two fuel pump combination I never have to worry about leanout at the top end. Don't laugh but probably 60% of the higher performance engines in use be a six cylinder or a modified 8 are lacking full fuel pressure at full throttle. If you find you have to keep jetting richer, you had best check your fuel pressure at full throttle. William
Just a thought Will, but AFAIK, these Holley fuel pumps are designed as pushers, not pullers, thus they should be as close to tank as possible, also in the lowest pick up point, so they're "gravity fed". ;)
Alex
Thanks, Will. I just noticed the placement of the fuel pump in the pick. Do you have an inertia switch or oil pressure cut off on the fuel pump?
Just wondering for saftey.
Marco, yes I do have an oil pressure safety switch.
Alex you are right the electric pumps are a better pusher than a puller. the only reason I placed it there was plenty of space & ease of installation. If I was feeding a worked small block v-8 or a big block I would have mounted the pump closer to the rear.William
If you notice all my holley carbs have the special bowls with remoable plugs so you can do a jet change without removing the float bowl.
When you purchase these bowls from holley they come with a special jet screwdriver which holds the jets to remove them. In the medical field its like doing laproscopic surgery. William
Thanks for the info William...I'm going with the Holly 500 for my Aussie Head.
I'm just curious what everyone else is using on their Aussies......
I have done some more testing with the 4412-500 cfm holley.
I have found it benificial to go to .030 or .031 accerator accerator pump discharge nozzle, especially on full throttle acceration from a dead stop. The extra pump shot fills in the slight lean hole on full throttle acceration especially from a dead stop.
Try it to see if it helps you with your combination . Wiliam
Nice looking set up :) How did you get your carby looking so shiny? Did you do t yourself or send it away to Holley for reman?
hoki, the body is the shiney finish on the 4412-500 with a holley chrome fuel bowl with quick change jet access.
All available from holley. Thanks William
Looks fantastic, you could eat your lunch off it :) Unfortunately very expensive in NZ for these Holley parts. I might have a talk to some electroplaters and see if I can jazz up my second hand 500. Thanks for the info
Denis
