All Small Six Interesting $599.00 bluetooth distributor for the Ford Small six
78_200_C4
Bluetooth connectivity to your distributor from your iOS and Android devices
• See real time data with the free app: See actual timing, RPM, and manifold pressure in real time while the car drives!
• Theft prevention – The built-in kill switch allows you to disable the ignition from your phone!
• NO mechanical adjustments through the distributor necessary
• Adjust timing for naturally aspirated, turbo or supercharged applications
• Built in rev limiter allows you to set your own rev limit
• High RPM capable – Maximum spark energy up to 10,000 RPM with no ignition box needed
• Save multiple tunes and change them on the go
• Built-in Timing Table Generator. Just enter some basic parameters and the app creates a timing table for you for easy tuning. • Includes multiple style caps
• Ignition Coil included in kit
Interesting and cool. I'd like to see some reviews on it, and a search revealed nothing. Thanks for the link.
Hard no, half my theft prevention is a stick shift!
Why does my new distributor need access to my contacts, photos, camera, and mic?:confused:
Because the CCP needs to know everything about your engine timing, comrade.
It has been out for a while.
It is the same distributor that PowerNation used on the 300 six turbocharged engine video that is posted in the Big Six forum.
I know how to use a screwdriver, vacuum gauge, and a timing light. Actually, just the screwdriver and a distributor wrench.
Maybe they will still be in business next year, maybe you can still find support in five. Maybe you won't need a monthly subscription to your distributor.
Carburetors work, points work, drum brakes work.
You can have a 60 year old '65 Mustang, you won't have a 60 year old 2020 Mustang, more likely to have a 120 year old '65.
I agree. I still have a carb and drums myself. I did swap the Load-o-Matic for an HEI, however.
I am selling one of those distributors (brabd new) here in the buy sell trade forum if anyone is interested
I don't need one because my 200 already runs so good + is so much fun to drive that every time I drive it is a pleasure feast.
this is Y we have chocolate AND vanilla, no?
(privately, no 1 is lookin, eh - I like the DSII, will use the 'gm 4 pin'
if/when 'the blue strain relief' box goes...)
