Hi everyone, been lurking this forum for a bit. It's been very helpful to me.
So, I've recently acquired a 1970 250 out of a Mustang which I plan to install into my 64 Econoline with an AOD behind it.
I've measured the current deck height @ .103" and the head chambers @ 65cc(only measured #1 so far)
I've now got it all torn down and ready to send to the machinist and have the block cleaned, bored, honed, decked and new cam bearings installed.
My plan is as follows
Bore cylinders .030"
Deck the block .020"
Have crank cleaned and polished and rotating assembly balanced.
Install Sealed Power P47830 pistons (1.582" compression distance) milled with mirrored chamber shaped dishes @ 8-9 cc's(found a cnc piston guy that will do it)
Moly Rings
Install Clay Smith cam and lifters
New timing set
Have larger valves installed - 1.75/1.46
New springs 289 or 302?
Install the adjustable rocker assy from my 144 and new cupped end pushrods
Carb adapter to Weber 32/36 DGV
My questions are these,
Which cam to use? Was planning on 264/264/112. Plan on using as daily driver around town, some highway usage, hence the AOD. Want it to idle smooth and will have auto and going to install power brakes.
Similarly how much to degree the cam, what is the practical difference from 0 to 2 to 4 degrees advance? What are the disadvantages if any or any of the configs?
Should I go with 289 springs or 302 exhaust springs with a 264/264/112 clay smith cam? I've read some contradictory info regarding this. This will be a daily driver for the most part and I don't want to needlessly wear anything by having too much spring load. Also, will either of these springs require modification to the spring seat or head?
Will standard length pushrods be OK with decking .020" and using the the adjustable rockers?
On the Weber, if I use the 1v to 2v adapter, will I need a spacer? If so what is minimum spacer thickness required to clear the valve cover? I have some height clearance concerns as it is going to the 250 in my doghouse.
With the above configuration what C/R should I shoot for to stay on low or mid grade fuel @ sea level? Right now I'm looking @ 9.2-9.3:1 depending on how much I deck the block and how much I dish the pistons. I may deck less if need be to bring it down without milling too mush out of the cast pistons. I can't use the tables at Classic Inlines for Dynamic C/R b/c my configuration is different.
Here's a possible scenerio,
Input Values:
Number Of Cylinders - 6
Bore Diameter [inches] - 3.71
Stroke Length [inches] - 3.91
Combustion Chamber Volume [cubic centimeters] - 65
Head Gasket Compressed Thickness [inches] - .050
Head Gasket Bore Diameter [inches] - 3.81
Piston To Deck Clearance [inches] - .001
Select Piston Type
Dish/Valve Relief/Dome Volume [positive cubic centimeters] - 9
Volumetric Efficiency: 85%
RPM: 4500
Results:
Displacement, [cubic inches] 254
Displacement, [liters] 4.2
Static compression ratio 9.3:1
Cubic Feet per Minute required @ 4500 rpm, [cfm] 281
Estimated Horsepower @ 4500 rpm - 167
Any advice or comments is greatly appreciated
Moly Rings
New timing set
Input Values:
Select Piston Type
RPM: 4500
Results:
