fast64ranchero
I ran into two problems when I tried to get my engine primed to fire up.
The first problem is when I primed the oil pump I never got oil to the rockers and it got me wondering if I have the correct lifters. I( need oil through solid lifters). Have any of you guys pulled a solid lifter apart? the one I pulled apart has a solid puck inside with no way that I can tell for oil to go through it to feed the push rod and rockers. If I remember right I need Lifters for a FE? If not what is the cross over lifter?
Thanks for the help
Thanks for the help
