Yesterday, before filling up with fuel the A/F ratio was pretty much dead on after going one jet size smaller. An issue came up right after filling up with fuel. The A/F ratio leaned out too 15.2 to 15.7. Typically, this is considered too lean for these engines to operate safely.
Later yesterday evening, a member here pointed out that the ethanol content
at the pump is not controlled well and can vary a great amount.
My fix was, I reverted back to one jet size larger to get the A/F ratio in check.
About a year and a half ago. I worked on a friend’s car. The car felt slightly sluggish and check engine light was on. Hooked up the scanner and did a diagnostic check. It turned out that the ethanol content was very high. I believe it was almost 30%. The cars fuel tank was near 1/4 full. So we filled the car with ethanol free fuel. And in a few minutes the problem was corrected. The code was cleared and check engine light went off.
The gas station my friend fills up at doesn’t sell E-85 so, mistakenly filling with E-85 is ruled out. It looks like the problem emanates from the fuel depots. I guess mistakes can be made. Unfortunately, we are the ones that suffer if engine or fuel system damage is done and it can’t be proven that it was a result of bad fuel during a fillup.
This morning I was thinking back and there was talk on this forum about a device called The Carb Cheater. I’m wondering if anyone has tried one. The person that makes these, mentioned that it is not a fix for a poor running engine. It’s designed for getting the most out a carb’d engine that is already tuned pretty well.
