The shop gets the bare block, crankshaft and connecting rods.
Most of the time you take the block apart and remove the freeze plugs and oil passage plugs paying very careful attention to where each oil plug came from. Also carefully remove sensors paying attention which hole each was in. Take pictures if needed.
Take the time to prepare marked ziploc bags so as you remove each set of small bolts from covers and other parts they are identified in a bag.
Remove the rod and piston assembly being careful not to let the rod bolts hit the crankshaft journal as you push the pistons out the top.
Tape the connecting rod bolt threads or use plastic tubing.
Remove the rod bearings and put the rod cap back on the same direction it came off.
The shop will need to press the piston pins out of the connecting rods to remove the pistons.
Remove the main bearings and put the main caps back on with the cap bolts snug.
Remove the camshaft with the gear in place for now.
You can leave the cam bearings in.
Then you can clean the block with a good degreaser, scrape gaskets off and begin your own inspection.
Look for sand/iron lumps in the crankcase surfaces and inside corners. If you find any then grind them away.
Remove all casting flash especially in the cam tunnel.
Finally radius all edges in and outside the block.
I picked up a 1978 200 a while ago, for no other purpose other than I was bored and needed a road-trip to New Jersey. The head has been cleaned and no cracks found. It is sitting on a shelf, partially pocket ported ... (for sale soon) The block has not been inspected yet. It is sitting on an...
fordsix.com
fordsix.com
