First, its not the peak fuel pressure from a Ford pump, its the surges up and down, and setting it at less than 3 psi takes care of it. So does using a stock Cater pump ex 1983-1985 302 4V HO, without a pressure regulator, but one return line. This is how all 1972 to 1992 Weber 2-BBL carbs were run in European and Australian cars in the 1.6 to 4.1 liter engines that ran these types of carbs. They used a bleed back valve, and there was no surge at the float bowl. The emulsion tubes were designed around a recommended float bowl setting, and the fuel pressure regulator is just a stop gap that works. People have funny ideas, a return line is the easiest way to take car of stock Ford pump pressure surges.
Float settings need to follow the recomendations used by Ford for the year and type of float.
The Stock Emulsion tubes vary depending on the type of choke, most European Weber 32/36 carbs are ex rear drive 1970-1983 Ford OHC engines like those found on some year 1.6/2.0 Capri/Taunus/Cortina/Transit/Granada/Sierra, and are sized to suit the vacuum needs of a 75 to 102 horsepower 97 to 121 cubic inch engine.
Depending on where they were sold (some were ECE emissions engines for Sweden and Switzerland, which used US 1973/1974 Pinto and 1976-1982 Australian Cortina jetting) and where they were made (Spain/Bressel/Weber), they have different set ups for float levels, return lines, float types with different settings, and base jetting and emulsion tubes. They didn't change that much. though, and there is a series number and details on them to figure out what should be there.
Stock emulsion tubes are Primary F50 /Secondary F6 on auto choke 32/36's, or Primary F50/Secondary F50 on manual choke.
The float levels need to be as recommended by
http://www.mgexp.com/phorum/read.php?1,1976705,page=3
I spoke to a technical representative at Pierce today. Here's what I found out:
1. The brass floated DGV carb should be set at 41 mm / 51 mm. (tab NOT compressing the ball valve on the needle valve). The needle valve will be telescoped inward on the needle valve mounting.
2. Measurements should be made from the base surface with the gasket on, not off.
3. The above measurements of 36.5 / 46.5 mm is only for a "composite" type floated carb using F50 and F6 emulsion tube pairing. This does not apply to the brass floated carbs.
I hope this helps. I didn't realize there were so many different configurations of the DGV carb.
If you've set your float level right, and dropped the pressure by whatever means floats your boat, you then
need to drop in two F66, F6, F7 or perhaps modified F7 with holes soldered up to stop lean conditions in the the cruise conditions. The jets and air correctors don't do much if the e-tube doesn't suit the engine size and vaccum requirements of a 200 Ford Six. The accelerator jet will help a little, but the two emulsion tubes will help the most. This is why, in 10 years of open sharing of info over the Weber 32/36, and Weber 38 and Holley 5200 series, there has been so little response to jetting changes.
On the Jeep forum, they have gotten into the Weber 61440.xxx emulsion tubes, and made some custom F-THIS ones very easily from some F7's to suit the 4.0 and 258 Jeep sixes with the 32/36 AND 38 series carbs.:mrgreen:
Based on previous experiences and this most recent work, I'm going to offer up some broad generalizations while it's still fresh in my mind and wait for your feedback.
The activation point and also the mixture strength of the main circuit is controlled by the emulsion tube to a much greater extent than the main jet or air corrector. It also is the key to how well the main circuit responds to large throttle openings and overall mixture consistency, once activated.
The true mixture strength or sizing of the main jet is measured down lower in the rpm range (2,500 rpm) at WOT and is influenced to a lesser extent by the lower holes of the emulsion tube.
The WOT mixture at the top of the rpm range is most influenced by and adjusted with the air corrector
http://www.jeepforum.com/forum/f8/weber ... ndex6.html
