krbostic89
Active member
Ok Gear heads.
I got my rebuilt inline 6 started and broke it in today! Problem I have now is that I cannot for the life of me get it to stay on at idle.
The set up, I have a Weber 32/36 mated up to a 1v/2v modified '69 250 log head. I also have the holley fuel pressure regulator that is at 2.8 psi that it comes out of the box. I used the Vintage Inlines weber 1v/2v conversion plate. I also have the Duraspark 2, dyna module, and inferno coil for ignition.
I worked through the initial start and tuning stuff from weber and had it set like the advertised. It runs smooth at 1000 rpm when I'm pressing the accelerator, but as soon as it drops, no dice. I was able to do the initial break in just fine, ran it for about 20 minutes cycling it from 2000 to 3000 RPM smoothly.
It just will not idle. Looking for any help or ideas, Thank you so much in advance.
