I just charged the battery. Volt meter reading across the pots is 12.45. Seems a bit low? Could that contribute to weak spark? I guess car actually runs off alternator right? I don't have any starting issues.
Just did this test.
To check the resister wire, disconnect the negative wire from the coil to the distributor, and replace it with a jumper to ground. Then check voltage at the coil positive terminal with the ignition on.
Voltage was 5.5. Seems low right? Enough to cause weak spark?
Thanks for all the help. Much appreciated!
Just did this test.
