Elijah Gerke
Well I have a 1966 mustang with a 1968 block and a 69 small log head and mated to a c4 auto. A couple of days ago I was driving around and had no problems, then about 4 hours later I decide to pull it into the garage because it was about to rain. When I started it sounded like it had a heavy camshaft in it(I do not have a heavy/Lopy cam) so I thought no problem probably one of the plug wires had a bad connection or my timing got knocked out, pulled timing and it was good. So i replaced plug wires because mine were a little worn, nothing still missing. I had just done spark plugs about 3 months earlier, so I thought couldn't be them, well somehow I had one bad one so i replaced it with an older one that i knew was good, still misfire after that. So i decide to do a compression test 120 on all cylinders except for cylinder 4 which had 150. So I went out and bought new spark plugs came back put them in still nothing, so I decide just to be sure i pulled timing and now after that it will not start at all and it just keeps on popping through the carb ive tried everything and I know I was on compression stroke. Eventually I got it started then it had a big backfire and would just pop through the carburetor again when trying to start, I have no idea of what to do next/what's wrong. I think that this has now surpassed my level of amateur diagnosis.
Btw when diagnosing the first time I did find a small crack in my distributor cap so I replaced it and it also did nothing for it
