1961falconrat
Hey guys! Well I finally picked up the engine I've been after, a 69' 250! Got it for $100 bucks! First thing I did when I got home was pull the head to see what I had found. I scored! the cylinder walls are great with no scoring or scratches and no ridges, the pistons look to be in good condition as well. The head needs work, #6 Exhaust valve has a chip out of it, but the seat of the valve looks fine. Anyway, I wanna build this engine to be a pretty healthy little beast, and from what I've read its not that hard to pull power out of it. I'm looking at a Comp Cam and lifter kit on summit, which is 260/260 Duration, .440/.440 Lift. and I'd like to go with bigger valves, im thinking the SI Port-Flow 1.75 from classic inlines. I have a local machinist that will do all the porting and honing. I'd like to go with a header, Siamese Port Divider from clifford, and an Electronic Distributor. I'm trying to stay away from boring and stroking for the time being because I don't have too much money haha. I have a 170 with adjustable rockers in it that are like brand new, should I put those in the 250? or stay with the stock ball-ball non-adjustable rockers? I'm not too sure what else to do, or if my ideas would work well, so i figured i'd ask you guys! I want to be able to drive it to school almost every day and go to the strip and turn a decent time. Im still in Highschool so I've got plenty of time for bigger modifications later down the road haha. So any Advice you seasoned Rodders can offer to a young rodder on what to put into this would be greatly appreciated!! Oh and also, its going into a 61' falcon wagon, I already have a c4 in it so all i need to do is build up this Engine and get goin! thanks again!
Vincent.
Vincent.
