2 bbl carb adapter for a 1 bbl intake
guys, i've already asked this question in the 240-300 forum and they sent me here. i have a 300 that we want to put an adapter on the original intake to take it from a 1 bbl to a 2 bbl. does anyone know of a supplier that might make this? the only thing clifford's offers is a 4 bbl to 2 bbl adapter.
What is the motor in....
are you sure it a 1 bb carb ??? I didn't know they put 1's on the big six's I thought they were all 2 b carb. does it have 1 or 2 screw's at the front of the carb in the base plate of the carb... if it has 2 mixtures screw's then its already a 2 b carb...
Tim
They put plenty of 1bbl's on the big sixes.
However, I question the wisdom of using an adapter to put a 2bbl on the 1bbl manifold when 2 and 4 bbl manifolds are available.
Tim
it's a 68 ford truck and original. it is definitely 1 bbl, i think it was the late 70's when they went 2 bbl from the factory.
this truck is just an old beater, don't want to spend $300 on a 4 bbl intake and then also have to buy a 2 bbl/4 bbl adapter.
Maybe go to a junk yard and find a 300 with a 2b carb and get the 2b manfold and carb for prob under $100.oo. just about any year would bolt up..
tim
tim
obviously that would be something we would have considered, but the factory 2 bbl setups that came on the later 300's was nothing to brag about, i've never heard anything but bad stories about those.
Howdy Back SD44 and All:
I'm assuming this truck has a 300 six???
If so it came stock with a Carter YF one barrel. FoMoCo used the YF series carb until they switched to FI. TTBOMK this engine never came from Dearborn with a two barrel carb.
The 300 truck YF was the largest CFM carb at 197. The Carter's have a wider bolt spacing and larger throttle bore then the Small six one barrels. So, it's likely that any adapter from a small six will have to be modified to fit on a big six. It will not be much of a problem as mounting holes can be slotted and throttle bore reamed out.
Have you picked the two barrel you'd like to use?
What is your goal for this truck?
