Tmacdagreat
Need advice on how to get my online 6 to between 200-300 hp
I see youve listed your home as Vancouver in BC, I worked for a company based there, Westport, they do still exist and did natural gas for engines, mainly truck and bus use. Have you ever heard of them? The comment I made is the easiest way to 200-300bhp, NA you would need a ton of work on breathing to get anywhere near. bear in mind the stock 200 is realisticly about 80bhp net, thats a long way short.where are you at with your engine today? Is it stock, mildly upgraded?
The head and log are the sore point. After you’ve cam’ed it and put better breathing exhaust and an electronic ignition, you either gap your rings for safety and put on a blower (or turbo) or you change the head, intake and carburetor. You’d want an Aussie 2V head or a Vintage Inlines or an Argentinian head.
If you boost it, don’t forget to gap the rings with more space so you don’t blow the top of a piston off. It tends to happen when people put on a turbo without considering anything else. You’re also probably going to want EFI if you boost it so the fuel injection can compensate for lean conditions.
My engines stock, and do have any links to an EFIwhere are you at with your engine today? Is it stock, mildly upgraded?
I’m in California, so is it easier to do a V8 swap ?I see youve listed your home as Vancouver in BC, I worked for a company based there, Westport, they do still exist and did natural gas for engines, mainly truck and bus use. Have you ever heard of them? The comment I made is the easiest way to 200-300bhp, NA you would need a ton of work on breathing to get anywhere near. bear in mind the stock 200 is realisticly about 80bhp net, thats a long way short.
Probably for you, yes. However you will need the matching drivetrain and brakes to do it right.I’m in California, so is it easier to do a V8 swap ?
Crow cams in Australia, do list cams for the precrossflow engines. https://crowcams.com.au/product/ford-pre-crossflow-hydraulic-4As previously mentioned, you will need a better breathing head with an intake manifold for a 4 barrel carburetor.
The other problem not mentioned is that performance camshafts for the small six are becoming non-existent and the few remaining performance flat tappet camshafts and lifters have a high probability of failure.
Tis the reason why roller camshafts were made available for the big block six.
The small bock V8 is the less expensive and more reliable way to go.
The 302 V8 can be anywhere from 302 to 347 cu inches using the 8.2" height block.
There are a wide variety of roller camshafts available.
A set of aluminum heads and an aluminum intake manifold will decrease the engine weight.
I totally agree. A 302 will be a much cheaper and more reliable option.As previously mentioned, you will need a better breathing head with an intake manifold for a 4 barrel carburetor.
And I would like to mention that Strong performance 302 blocks are also available from Ford Performance and Dart.A set of aluminum heads and an aluminum intake manifold will decrease the engine weight.
