200 Pushrods
Hodgie1013
Active member
During a head gasket change on my 200, I discovered a couple of bent pushrods. So I'm going to go ahead throw a new set in. Does anybody know of a heavier pushrod that I can use? Otherwise I'll just go with a stock replacement set, which I also need a line on. If anybody can help, it would me much appreciated. Thanks.
Matthew Haugland
edit- found what i needed. thanks
I'm pretty sure that I didn't have them seated in the rocker arm cups when I re-installed the stanchion. They were straight when I removed them. Oops...
