I66coupe
New member here. Rande's the name. have some mild mods I want to perform on my car. I look to the body of knowledge here for some guidance. I have read quite a bit here before posting but still have some questions.
I have a 1966 coupe with the 200 engine, 3 speed tranny and 3.20 open rear. The weak 2.77 tranny has blown, I am planning a T5 swap and then some engine upgrades. The car presently has 41,000 original miles and runs great. I am using a T5 from 1990 4 cyl. Mustang for the lower 1st gear and the lower overdrive. I am looking for a mild performance upgrade with an eye to efficiency, drivability and reliability. I don't want to drasticly change the appearance of the engine compartment. Headers, multiple carbs and cross-flow heads are out.
I have some questions about the engine. I want to use a later head for the hardened valve seats. I understand that I will need use a post-74 head and will need to shave .075 from the head to regain the lost compression, use a .050 gasket and the pushrods won't have to be shortened. If I use a pre-1980 head, I won't have the manifold mounted EGR port to worry about. Will this head come stock with bronze valve giudes? If not, should I have them installed? I was planning on a 3 angle valve job. How about aftermarket springs, retainers and locks? Don't wish to spend the money for roller tipped rockers, they seem to be very expensive. I know they would be advantageous but I don't have unlimited funds for this. I am planning to have Pony Carbs restore the 1100 Autolite carb. With the later head and its slightly larger intake log, would I be better off switching to a 2bbl? With the carb under an air cleaner, it won't look very different from stock.
For the cam, I was planning to use a stock 250 unit. I understand this will give me a mild performance boost without any bad manners or lopey idle.
How about exhaust manifolds? If I have it correct, 1969-1970 250 will give me a stock looking manifold with larger passages, and a larger outlet with no emissions holes to plug. Any other years to look for?
Then a DurasparkII distributor with an MSD5 or perhaps an MSD6A box and an MSD Blaster2 coil. What years to look in for that Duraspark distributor?
Any thoughts on what I am plannig here? I use the car for cruising, and occasionally driving to work. The majority of its driving is on local highways and the interstate. I live in a small city but most of my cruising is out on the county 2 lanes, enjoying the car and the countryside (southeastern Minnesota). I need to replace the exhaust manifold due to some nasty cracks. I want to install hardened valve seats (otherwise, there's nothing wrong with the head) so I can stop feeding it lead substitute. I need to repaint the engine and some of the engine compartment.
So, since I have the engine out for the tranny swap and want the head work done, the exhaust manifold replaced, I thought I may as well upgrade things a bit.
Thanks!
Thanks!
