I've gotten 8 years out of one of my 250's, so I'm not anti 250 at all. But I've gotten 4 years out of my 200, and love it even more.
Then again Parkwood60 has blown up a heap of 200's.
I remember what Falcon Sedan Delivery said. Get a Durapark II. But his advice made your DUI work brilliantly for you. Then he said Put a 600 4-bbl Edlebrock on it. But then the 2100 Autolite and 390 cfm worked to give over 123 hp (155 flywheel hp), up form 78 to 80 rwhp (111-113 flywheel hp) with the 32/36, a 36% boost in power.
Remember that with just 450 cfm of triple carbs, he made his 250 run low 14's.
For straight line power, go cubic inches.
So I'd have to say that if you just follow Falcon Sedan Delivery's advice, you'll probably avoid the costs most would incur doing a 250 swap.
I guess what I'm saying is that if your able to network, you can make a 250 really work well, and it will be fun, and you'll maybe make budget. That's why we talk, so we get the right answers to problems.
The Silvolite #1185 and Sealed Power 489p pistons are a solution to a problem. Stroking, 6" rods and using ones brain to make everything fit is also good.
Your 4cylinder T5 won't like the awesome power a 250 can make if its done right, nor will your 8". Our Alloy head 250 weighes in at 481 pounds dressed, without power steering and a/c, 144 up on the alloy head US 200 which is 337 pounds dressed, so your US 250 must have a lot of metal taken out of it. You might not like extra pounds over the front end. But I keep looking at FSDs old triple carbed Mustang and how it made 220 hp with just three stock Autolite and Holley carbs and I know anythings possible.
And he did it all with the stock defective 250 timing gear on a ballistic compression ratio
http://fordsix.com/forum/viewtopic.php? ... ng#p447439
And known problems with what happens with triple 1-bbl carbs under acceleration.
For 250 quarter mile figures despite all the problems a 250 has, see FalconSedanDelivery's old beast.
http://fordsix.com/forum/viewtopic.php? ... 31#p502631
FSD set up is very creditable 200-225 flywheel hp, and most likely the most powerful triple 1-bbl around. He ran a unison linkage, high initial advance of 16 to 18 degrees, total timing to 30 degrees its all in at 2350, decked block 100 thou and head 120 thou for huge 12.3:1 C/R, and the worlds neatest tri power intake ever seen. His best was 14.39 @ 91.76 mph one hot June 2011, and was shifted at 5000 and 4300 at the traps, earlier runs were 5200 and 4700 rpm. He ran with 3.5:1 gears for the 14.39. Best 60 foot time 1.915 secs in a 2600+ pound car with a an estimated 165 at the rear wheels. That's a minimum of 220 hp with a C4, probably more
But then I look at other great engine builders, and see that even the better components still fail
