65_Stang_170
Howdy,
Some of y'all have followed a couple of my threads about my "new" aluminum head and 250 block (with broken piston). I have finally got the block on an engine stand. I drained the oil (had coolant in it...), removed the oil pan, and removed the #6 piston which was busted up and caused damage to the aluminum head. Here are some pictures:
The pistons look to be custom; they say Dan's Machine on them with some numbers that probably have some sort of meaning unknown to me. The rods appear to be stock '69 250 rods (forged?). ARP studs/bolts. The pistons appear to come flush with or maybe a little above the deck of the block, so the deck has been machined. The water pump bolt head bolt was shortened to help confirm that as well.
1. I'm hoping a blown head gasket was the cause for the coolant in the oil. That or they didn't drain it very well when disassembling and coolant from the head went into the oil when they took it off... Other than that, what could be the issue or a way to check?
2. I need to degree the cam shaft to confirm what it is: do I need to remove the balancer and/or timing chain cover to do that? or can I attach the degree wheel to the balancer and it work the same?
3. There appears to be damage on #1 piston that was covered with grime. What does it look like caused that? Valve interference?
4. Do you think a machine shop can match the piston? or is it better for me to buy a new set?
5. Any idea what the number on the bottom side of the piston means? It says "w/o-228-16"
I'll leave it at that for now. Thanks in advance!
-Shawn
-Shawn
