Nevadasmith
Active member
At a lot of my refuling locations I suspect that the octane is less than advertised. And in the remote areas 85 octane can be $4 + a gallon when local gas is around $2.65 I'd like to error on the side of caution. I've built hi torque v8's with small duration cans and had detonation problems so bad I killed 40% of the power killing the timing to stop the pinging then had over heating problems. I'll stick to 9.0-9.25 to 1 even if I'm leaving a lot on the table, but I'm leaning towards the Schnider 248/256 cam or the Jones 248 cam. Thanks again for all the input! 16° initial timing made a small improvement but it's really hard starting now??? I had never hooked up the "white wire" on the ds2 today I did to the start side of the starter relay it would only crank, so it's disconnected and I'm back to 10 initial
congrats on installing the bigger and better sized exhaust system for your 250 and also on picking up the 1.08 Motorcraft carb that's about the perfect size for a 250 engine. With it being rich at idle first make sure the wet fuel level is set correctly and also check your fuel presure too. Then make sure that the choke is fully open before doing the idle mixture is set to the best lean idle setting. If you don't have a vacuum gauge you should get one it will be a big help in getting the tune up dialed in. I can't advise you on the size jets that you might have now though but that's the real beauty of those Autolite / Motorcraft carb's you can pull the top off and check fuel level, jetting, and economizer valve rating, all with it still bolted onto the intake. When it's set up right it will also give you the best in MPG of most any other 2V carb. Good luck
