starting my new motor soon, a 266cu x-flow, solid cam, etc.
boring a std block to 240 thou then fitting 6 sleeves and boring to 120 thou over standard. this will leave 60" wall thickness in steel, not cast iron.
using std 3.8inch v-6 holden vs clip pistons in acl race series.these have the right deck hight without decking the block.
then using std 200 rods with bushed small ends to holden pin size, shot peen, beam polished and arp bolts. the top of the small end needs to be machined to a slight tapper to fit into the holden piston.
with a bore of 96.5mm the std acl race head gasket will just fit at 96.55mm.
now with a 3.8 bore and a 3.91 stroke i think it should alot better than a std 3.68-3.91..
i saw a 250 get fitted with 3.85 pistons for a speedway motor on methanol last year and it split down the centre after 3 races, but that was over bored too much with 80" cyl wall sleeves, but not much left of the block to hold them.
im taking 3 blocks into the borer first to see which one has the most meat left after the 240" holes are bored.. i think some block filling will be needed..
cheers..
cheers..
