Okay, it's been awhile sense I've posted anything about my independent runner setup. It started out as an experiment in "how much mojoe can I get out of this log?". Now it's more like, "how complicated can I make this experiment?"
I've followed alot of Deano's research and responses regarding the use of an independent runner system on our I6's and deceided to give it a try with three Webers'. Not single venturi's, no, 2 bbl progressives to be exact.
Well, after running into head problems (lol), I finally could see the finish line. But that's when time sllllllooooooowwwwwweeeeedddddd ddddddddoooooowwwwwwnnnnn.
The log is almost done. But I'm having a bear of a time with linkage. Maybe someone can give me some hints.
Picture the "log" ...angels singing in back ground... anywho, the log. I have mounted two funnel adapters to the log and plugged the middle factory hole (I promise to post pictures tonight). I wanted to directly mount the Webers but considering they are progressives, I didn't think it would matter that much - except at WOT which wouldn't be seen much in reality. So, there you have it...got it?
Now, linkage. HELP!!!!!
For those of you who don't know, the 32/36 throttle rotates forward if mounted sideways on the log (fuel bowl facing the valve cover). Actually it's more like up and forward. I was thinking about going cable throttle but I'm not sure if that would work because of the throttle action.
Ideas? Thoughts?
Anyone want to finish it for me? :roll:
Ideas? Thoughts?
