Is there any difference between the distributor used in the '48 H series flathead six and the distributor from the '49? My parts books show it as the same part number but I often see the distributor listed as '49 and later.
I've never seen a '48 distributor out of the engine - is it spline drive or is there a gear on the end of the shaft like "modern" distributors? The drawings I've seen make it look like the oil pump has the drive gear and the distributor shaft fits into that assembly.
OK, so I'm new at this.
Thanks,
Ed
Thanks,
Ed
