8) you might try the 575 road demon carb instead. i think it is a better match for your 351w. also there is more to secondary operation than just vacuum or mechanical, at least on the mechanical side. you have full mechanical secondaries, that either have twin accelerator pumps, commonly called double pumpers, and you have a carb that is race only called a center squirter that uses a single accelerator pump and the pump outlet is literaly in the center of the carb, and directs fuel to all four barrels at once. then you have the avs or air valve secondary. it is a mechanical secondary carb, but there is an air valve that is controlled by air flow through the carb. when enough air weight is applied, the valve starts to open as needed to feed the engine. two carbs that use this system are the rochester Qjet and the carter avs.
