Hey all, I have the opprotunity to buy two running 200's, one from a 78 Fairmont and the other from an 83 Zepher. Other than the oil pan is there anything else that will prevent either of these engines from fitting in a 68 Mustang.
If I'm correct I think they have the Fox body oil pan. Will one from the older 6's fit? Will I have to change the oil pump?
If the 83 has the low starter does that mean it has the V-8 bell housing pattern? If so is it a dual pattern that my manual transmission bell housing from my 68 with bolt up to or do I need to source a V-8 housing.
If I bought these they would just be backups to my motor. I will probably rebuild one of the short blocks but if and when I install it I will use the modified head from my Mustang, and remove all the smog related equipment.
Since I plan on installing a turbo on my, other than a cam and double roller timing chain, stock lower end I will probably end up needing a new motor sooner rather than later he he...
As always thanks for all the advice from the forum.
Bob
Bob
