Guys:
So I have a about 1300 miles on my rebuilt 6. To refresh your memory, it's a 200 with a CI head ,Yella Terra Rockers (I plugged the oil port for the stock rockers), HSC flat top pistons, stock crank and stock forged rods. I have a Clay Smith 264/274 cam and used a new Melling pump when the motor was built.
Break in went well and the engine runs great. During break in miles I noted that cold the engine would show just under 50 PSI. When warm, at idle it would show about 20-25 PSI and at 2000 RPM and up it would show 35-40 PSI.
I changed the oil at 500 miles (10w-40 Mobil 1 and ZDDP additive). I'm seeing the same pressures. I've read that lower pressures just mean that the oil is circulating easily through the motor and is fine. Is this acceptable?
Thanks!
Thanks!
