Yes.
I will not publish the 'recipe' until I've checked that it actually works. The last of the three parts will be here in two weeks...then I'll figure it out. It's going to be a double roller, and one of the parts is going to need some machining. The other two: stock Ford...
Meanwhile, it is easy to make your stock set adjustable. IF the crank gear is not hardened and thus can be easily machined, just have a few slots done to it at the shop which has the right machinery with a degree table. If the crank gear is hardened like in a Powrgear brand set I have, just do it on the cam gear. Seems like it is safe to do two slots on the cam gear (you'll figure out where), just bear in mind that it rotates at half speed and a degree there is two degrees at the crank.
Another no-need-to-machine-anything method is to use offset keys at the crankshaft.
