This is the best way to adjust valves, solid of hydraulic.
With solid lifters set the lash.
With hydraulic tighten no more than 1/4 turn from zero clearance.
Turn the engine over till the exhaust valve on the chosen cylinder just starts to open, then adjust the intake valve on that cylinder.
Turn the engine over till the intake valve is just about closed, then set the exhaust valve.
Do the same procedure on the next cylinder. Bill
courtesy of falconsedandelivery
