Upon upgrading from a 170 to a 250, the operating temperature has increased dramtically in our Falcon... I am running no thermostat, a 2300 cfm electric fan, and a 50/50 mix of antifreeze and a solvent designed to help cars run cooler. It seems to run around 200 degrees under normal driving conditions, and I haven't had a chance to sit in traffic yet... I think that 180 should be an ideal operating temperature and maybe 200 in traffic...
There is nothing I can really do with the fan situation, I am using it as a pusher instead of a puller and it puts out a decent amount of air... I'm sure that the old radiator is full of sludge in the bottom and probably could be improved upon.. Would using a V8 radiator be possible? How is it different than the 6 cyl one? They are the same dimensions but have a different part #. A new V8 radiator is actually $10 cheaper than the 6 counterpart.
