Hey in liner, this is what I thought. Not quite sure which one is best. I'd appreciate your comments, as I don't want to put any one wrong!
From my understanding, I thought both 188 ME and 250 2V had split intake runners with the carb at right angles?.
On the Aussie one, it isn't good when you have a 32/36 or 5200 Holley, but on the 188 ME, it is!
188 ME intake was designed for a
progressive 2-bbl Solex carb, similar to the 32/36 Weber and 5200 Holley Weber.
221 SP intake was designed for a Holley 2-bbl carb with both barrels that open
at the same time. Eg Autolite 2100, Holley 2300 (350?500), Weber 38 etc.
250 2v intake. Shamelessly stolen from addo, (who is 34 soon!)
This is designed for a
non progressive Bendix/Stromberg 2-bbl, Autolite 2100, Holley 2300 350/500 2-bbl. A 38 Weber is also good. Although 5200 or 32/36 can work, they are not recomended as it favours certian cylinders due to the split divder in the intake runners.
http://img.photobucket.com/albums/v223/ ... v_plan.bmp
On some engines, like the X-flow 200/250 engines, a progessive Weber ADM 34 or a Holley 2300 can work.
