Hello All, I've read that the 1100 came in 3 Venturi sizes over the years. How does one go about measuring the venturi size? Where exactly do you measure, and if it's at the most narrow part of the opening, how do you get in there to measure? Thanks
Make a go no go cage. Take a coat hanger cut it up bend a L at one end ,trim L until it just fits and measure with regular tools. May have to form it some and go from base side.
Adam,
U can buy the jets on the net.
Look up under that carb. I'll do a search -
(thinkin Mike's, Datona, humm, er, ah….)
Back later. Pic to C where to remove/install:
