Hello,
So, I've been playing around with my float and jets, trying to get this thing to run and idle right. It's had it's gremlins, but they're on the run.
I went through my shop manual, checking everything as far as specs and settings and all that. I've determined that the shop manual is a good starting point (or not). I say this because the relationships in the fuel bowl have to be different with aftermarket rebuild kits and jets. Unless you've got a stock of NOS 1960's parts, whatever is now in your carb is close but not exact.
Sure, I acknowledge I might be misguided here. But, I'm tuning it in the right direction. Please let me know if I'm on the wrong track!!
There's multiple things going on with my car too. Carb was switched from a Holley 1940 back to a 1101. Distributor was changed to a DUI. Engine was rebuilt from the ground up. Different Cam, valves, etc etc.
Here's the main question I'm trying to figure out because it's a pain to pull the top off the carb when it's hot. So, tomorrow before I start it up, please have an answer for this
The Question is...
When the engine is at operating temp, I'm having a hell of a time getting it to idle smoothly. It idles smooth when warming up on choke.
What RPM should this thing be running around when cold?
I've checked for possible vacuum leaks.
I haven't been able to get it to idle near 600-700 to set my initial advance.
I'm suspecting float level setting. I started at the manual's recommended 1.09. That sucked too much fuel at idle I think. I set the float higher. This was better, but I only went up a 32nd or so. I was able to get it to idle down a bit, but still not smooth. When I look down the carb hole I can see fuel rain dropping in, but not as much with the 1.09 setting. I am using a 66 jet. I have 62 and 64 jets to try also.
And - I did the 1/16 drill bit setting of the fast idle and carb plate and throttle plate. What appeared to be happening to it was that it looked like the fast idle cam would never ever come into contact with the adjusting screw. Does someone have pictures of this arrangement - Mostly interested in the relation of the fast idle choke cam and it's screw. The steps for that cam to me appear to be worn - I don't know what good ones are supposed to look like.
The links below are a carb worksheet with an illustration of what I'm trying to figure out...
The 1.094 setting was on the flood side of the equation... I haven't found the 'Happy' setting yet.
http://www.xtuple.org/ppc/carbworksheet.pdf
The Question is...
